- 11 Mar 2013
- United Kingdom
Using Corsair Vengeance 2666mhz 2x4GB. Tried using just one and tried all 4 of the slots.are you using compatible memory with the ryzen setup?
It will not boot with GPU in our out, with different GPU in it, with just one RAM stick and tried it will different HDDs and with the bare minimal installed.My guess is you've run out of memory available to oprom for the card to initialise. If you take stuff out does it work again? Can you go in the BIOS and disable net oprom/net booting, and any other hardware you are not using like serial, parallel, firewire ports etc.
First time I hit this was when adding 5 x 2 port gig nics to an old server several years ago. Only 2 of them got initialised.
Ordered a PSU so will try that tomorrow and post the results.
