Tried&Tested said:Mine on stock cooler:
Not a lot of difference if you ask me. In fact, my temps are a little cooler.
What util produced those temps etc?
If you're running a C2D system, you should just be able to crank the FSB up a bit and get a good overclock without messing with your CPU vcore, you might have to tweak your RAM timings and/or voltages a bit though if you want them to overclock that too. In terms of temps, having a difference between the 2 cores is nothing uncommon, there's about a 5 degree temp difference between the cores on my current AMD system.Jaridan said:I have just installed one of these on my E6600 and im getting a slightly wierd reading in the sense that one core is usually 1 degree higher tempwise?
Just running stock at the moment but i am tempted to overclock.. Is it viable to overclock and leave the settings once stable or is it more a case of push the components are far as possible then revert to normal settings?
As mentioned above by El Juimben its not uncommon or anything to worry about the core temps being slightly different. If the core's are dramatically different to the CPU temp itself then you should be worried. Increase the FSB, you should be able to hit 333 without having to alter the voltages. I would return RAM settings to default so that you can determine the best overclock on your CPU first. Anything above 3GHz and you probably are going to need to alter the voltage slightly - mine is 1.29 and my E6600 is at 3.5GHz.Jaridan said:I have just installed one of these on my E6600 and im getting a slightly wierd reading in the sense that one core is usually 1 degree higher tempwise?
mishima said:Hi,
Sorry I haven't got back to you I was suspended from the forums for listing a competitor. I would have the fan closest to the RAM blowing across the heatsink in the direction of the exhaust.
Dan7 said:Getting my Noctua on monday and I'm a little confused!
Where is the best place to put the fan, and in what direction?
(I'm using an Akasa Eclipse 62 case if that makes things any different)
Dan7 said:Finally managed to fit it in (It only mounts so that the fans point up/down :E)
However I made a schoolboy error and accidently broke a fin on the fan :/
It's causing a fair bit of vibration and speedfan is reporting the Core at 51 degrees.
I've ordered a replacement fan (+ an extra one for the other side of the heatsink!), I'm thinking it's safe to carry on using the PC? (If the temps rise about 60 or so I'd start getting worried)
