Your neighour is being very reasonable in asking you to turn your music off at 10pm. I wouldn't put up with thumping bass through the walls at any time of day. The low frequencies resonate through floors and walls even at lower volumes.
try playing with the angles of your speakers if possible, generally if they arent pointing directly at you the base will sound bigger meaning you can turn the base down slightly but with the same boomMy speakers sound really quiet in my room, but the bass from them is much louder in other rooms of the house.
Because low sounds travel further than high sounds.
You say your at uni eh?!
Sit your sub on a pillow or something.
Its happening because bass is not affected by walls in the same way as other frequencies...
The first article here shows a good explination as to why, but your right its an odd, yet annoying one as it never seems to matter how low you turn the bass its still too loud...
http://letmegooglethatforyou.com/?q=why+does+bass+travel+through+walls&l=1
If you are all students then I don't see issues playing it until 11-12 although it's hard to know how loud your playing it and how bad its ******* the student off nextdoor.
wow, you must be a great neighbour
I would blaze this out if you were my neighbour:
http://uk.youtube.com/watch?v=12z1NI4C4Vk
And remember to turn volume and bass up to max...
Thats not a bass test.
Try Woofer cooker, THX - Worlds Deepest Bass, songs by bassaholics etc...
I've tried woofer cooker
tbh the chemical bros tune is loud enough to shake my whole room like mental![]()
