Noisy Hard Drive on Boot up only.
19 Jul 2006
Hi all, my HD (which is about 2 yrs old) has started to make a zrrrrr-ing noise when I boot up.
The boot goes flawlessly (and seems quicker but could be my imagination) and the zrrrr-ing stops when I get to desk stop and I never hear it again or have any performance problems.
Except when I install games: the install takes ages.
I suspect my HD is dieing; does this sound the case? The PC potters away quite happilly at any other time, just on boot up does it get the zrrrrs.
Any ideas what it is?
P4, 3 GHz
XP
1 G Ram
6800 XT Card.
Thanks in advance.
Unfortunately no. It sounds like faulty DVD drive but I checked the PCs DVD drive and its not spining when I hear it.
Sorry I can't be any more specific.
I had a WD 80GB drive die earlier this year, and this is what it sounded like - a faulty DVD. It sounded like a sort of click then a whirring noise.
If I were you, I'd be backing up any data on the drive just in case!!
It's more a constant zrrr-ing, like the rotation of a tiny propeller. My fan works a ok though. It's not the click-tsst of a dvd drive not reading a disk, more a constant zrrrrr-ing that cuts out just before my desk top pops up in the boot sequence.
Just today it went away for two boots after I accidently kicked the tower. Could it be that the screwws are coming loose somwhere?
Have a look on the manufacturer's website for a diagnosis tool. The WD site has the WD Data Lifeguard software that can run diagnostic tests for faults.
My 4 Htachi drives do this when you turn the computer on, sounds like horrible grinding at stuff...
They've been doing it for about a year though so...
I guess its normal (only during bootup and shutdown, never had any loss of data, and its a 4 x raid0 jobby so i doubt anythings wrong)
...not to say there isn't anything wrong with yours, just as long as you haven't got anything critical on there, i wouldn't worry, hard drives are cheap as chips these days.
I know what you mean as my PC is VERY loud when it boots up, it's grinding away like hell and causing massive reverberations, you can easily hear it from a couple of rooms away.
The realworld write speed on one of my drives is very poor for some reason but it's been like this for a while.
Thanks for the info, I think I will have to chance it for a month or two (till I get my raise!). My PC is a games machine anyway so no real stuff will get lost if it dies.
One last question though: Do new HD caome with an operating system on them?
