Noob RAID help needed!
6 Jan 2004
West Sussex
I just received 2x Seagate 250gb Sata2 drives which i am trying to make into a RAID 1 Array to back up all my files etc.. Now the thing is i have the drives plugged into the Promise SATA ports (red ones) on my Asus A8V Deluxe mb and the drives were detected by the Promise Fastbuild utility on boot. I went in and set up the basic parameters and everything went ok, and on the next boot the fastrack378 BIOS shows the array at its correct size and says its functional.
Problem is that the array is not recognised in Windows, i have my CDRW, and my 2 old HDD's but nothing for the new drives. Is this because they are not formatted in NTFS? If so how do i go about formatting them outside of windows?
Thanks for any help! (and sorry for the stupid question lol)
You have to install the promise controllers, so that the fasttrak array can be seen in windows. As soon as you have installed these, then the array should become available (you many have to use disk administator to assign it a drive letter)
The drivers for the controller are on the CD that came with the motherboard.
You can get to disk administrator by right clicking "my computer" then clicking the manage option, and it should come up in the console under the heading "disk management" (in the storage section)
Thankyou so much! I had the drivers installed already, but i had no idea about the management options. Seems for whatever reason the array had not initialized automatically, so i did that manually and assigned it a letter, just got to wait for it to format as NTFS now :)
Really appreciate the help, i would never have even found that management option if someone had'nt of told me lol
