This, Phantom Spirit is even better. I tested it with 1 fan fitted and on 7800x3d it performs more or less the same as full custom loop.
You can try, but from my experience its very hard to not put enough if the cooler contact is fine. Most people put too much.I have just watched the phantom spirit video and was amazed at the amount of "gunk" they put on (a great glob! - partic see the video on the rainforest site) - I put a few mm mini glob - perhaps I didn't put enough? Should I try a bit more?
At BIOS seems to run all the time at 4.7MHz? so runs quite hot?Some cpus run hotter is bios as that don’t idle down that sit at full base clock
I ran cinebench R20 and it went up to 79 deg C.
You should set an offset in bios if you haven’t already.
Bit of a novice in this area - what does set an offset in BIOS mean?
Thanks - I'll try that another day with a clear head!find the "AMD overclocking" tab in there you can set a voltage offset it will reduce the voltage curv of the CPU.
you will need to do it in steps it gos from 0 to 30 in steps one 1, i tend to go up in 5's
my CPU runs at -25 and it drops the temps a good bit.
Not the best video but it as all the info you need
How to overclock 5900X PBO + Curve Optimizer / Overclocking Tutorial Guide / Temp on Noctua D15
Ryzen 9 5900X temperature test on Noctua D15 (Custom Silent Profile). PBO + Curve Optimizer enable. All other bios settings at stock. This guide can be used ...www.youtube.com
I said it would idle in the bios
As in there's no background processes there
To make the temperature jump around like in windows
Didn't say it would downclock the frequency
??Bit confused AMD BIOS has "GAME BOOST" as an option - do I need that?
Probably a default overclocking profile
Ta.Probably a default overclocking profile
Usually those aren't great
Tend to push more voltage/heat
Think it's a msi setting
Though other manufacturers can have it with different names
Does that mean something - or is it 3 words picked out of the air! Joking apart thanks for responding but I do not know what that means! BUT looking at google it's to do with CPU / graphics performance in games. I don't do gaming so I will keep it "off" in BIOS.IIRC it’s a dynamic resolution scaling tool.
Thanks, Mel
