ThisSupercharged please, best of both worlds![]()
That's exactly his point. Mine starts working at 2.5k as well, and below that it has all the pulling power of a 1.0 Litre Micra, at ~2.5k it's like a switch being flipped. Turbos don't have smooth torque characteristics.
Mine has enough pulling power when off boost (2 litre straight 6), and the lag is virtually nothing since it revs freely enough. The lag is less than the lag you'd get waiting for the kickdown on an automatic gearbox that you'd likely find mated to a big V6/8 on a luxobarge.
If the pathetically small amount of lag on a sensible turbo setup makes such a difference that it actually causes you a problem then you aren't planning your manoeuvre far enough ahead and shouldn't be allowed to be in charge of anything bigger than a 1 litre Corsa.
If I need to get some instant grunt I just kick the clutch pedal to let the revs rise and spin up the turbo (a bit like 'clutching' a 2 stroke bike to get into the power band), but then they aren't my cars and I'm not paying for the clutchesMost 'lag' is resolved by dropping a gear and properly citing your engine rpm well in the boost threshold.
