- 14 Apr 2010
- swanley,kent
hi,
right i have the system in my sig. now i have my cpu set at offsett 0.020 in bios which gives 1.38 in cpu-z at 5ghz.it's stable at those temps.my wc setup is as follows,an xspc ex480 in the bottom of the case with 8 vipers in push/pull pulling air into the case, an xspc ex360 in the roof of the case with 3 vipers pulling air through the rad and out the top. i have 2 gtx470's with full nickle ex blocks and the cpu block is an ek supreme full nickle. i have 2 laing 18w ddc pumps working in tandem all on one loop.now when i game i'm seeing tempos up to 85 and under prime it's going up to 80 within 2 minutes.now i have been using this like this and was happy. b ut i'm seeing posts where ppl are getting lower temps with high end air coolers and higher volts. 5ghz with 1.38 volts i think is awesome but surely with my loop i should be getting much better temps????
is there anything you would change about my loop, i.e setup or fan direction ect??
my fans are controlled by pwn on the motherboard.maybe set them up in another way???
