Drivers up to date and whql?Can someone help out please
I'm getting a pass 94.2 not passed on my 3D mark test [fire strike extreme test ]
And that's about all it says
Any ideas how i can find out what's failing to get to a pass mark of 97 please
Exactly this, the stress test is designed to 'measure' if your PC throttles at all during the test. It doesn't mean you have a problem, just that the hardware is being restricted in some way.I take it you're running the stress test, can you see what temps you are getting on your 2080?
I would guess that it's your card throttling due to heat that is causing the failure, put your fans speeds up and see. the test isn't designed to be run back to back because you're looping 20 tests together which is more stressful then normal gaming
