hello all, looking for some advice, ive recently upgraded from a 1080ti to a RTX 3070, and i keep getting the same problem no matter what i do,
so ive unsitalled all the old Drivers via DDU, and then installed the new card and downloaded the new drivers via the geforce now application, the card then works great, i play warzone no problem, until i close the game and then turn off the computer,
upon restarting the computer boots up, but keeps insisting on installing the latest drivers, which i have already done previously, then the card stops working in device manager with an error code of 43, the card is not working properly it says but is still outputting to the screen, no games will load up nor does it find the card in GPUZ or on any monitoring systems,
lucky enough ive got a back up rig, and ive put the 3070 in there and it games as it should with no error codes or anything, do you think a fresh install of windows will solve this?
specs as follows :
AMD ryzen 7 3800x
32gb Corsair DDR4 32000mhz ram
MSI Tomahawk B550 Motherboard
RTX 3070 aorus Master card
Seagate barracuda 250 SSD (windows 10 64bit)
various SSD for Storage
any help will be greatly appreciated
cheers simon
specs as follows :
AMD ryzen 7 3800x
cheers simon
