 - 8 Oct 2008
60hz = max 60 fps.
60hz = max 60 fps.
Given how crap the currant 120hz monitors are it's not worth it and even if 120hz screens were up to scratch the price/benefit ratio just doesn't add up in the long run. Your better off spending your money on a better video card or better monitor like the Dell U2410 Ultrahsharp which puts those frankly awful 120hz screens to shame.
No it does not.
In the case of 3D 60Hz is a problem.
Refresh rate is the maximum the monitor will update per second, frame rate can be as high as it likes regardless if the display device can keep up unless V-sync is used.
The current 120hz monitors have scored highly in reviews. Especially on the gaming side. Whilst monitors such as the Dell U2410 are great, they are not as good for gaming/3d. - whilst they would excel in high end photo work.
You are confused here. Frame rate is limited to the monitor refresh rate. If your monitor (regular lcd's) can only handle 60hz then the max fps they can do is 60fps. This is why some fps players still use crt monitors as they can handle a higher hz and thus a higher fps.
The Zalman's are unfortunately are older end off line tech. And not as fully supported (they have there own drivers-not 3d vision). Whilst they do perform pretty well, The support is a limitation. Also they use interlacing so you get a 1680, 525 resolution.I came across the Zalman Trimon 3d Monitors last night, has anyone here tried those out?
As a rule as each regular frame is rendered from 2 different angles for each eye, you get approx 50% performance hit.Does 3D Vision affect the performance much?
Indeed the 3D side of it all, is too much for me with fast pace first person online shooter games where you are constantly refocusing on different parts of the screen. It's doesn't cause problems, it just doesn't help. The 120 frames per second from the monitor in this situation is more beneficial. Tactical/RPG/Racing/Even single player fps games the 3D is great.I don't think you could do serious FPS gaming with it...
No offence but that's an ill informed comment IMO, stereoscopic vision sends different images to each eye, therefore directly hacking into the depth perception your brain does, so when it's working well it's as '3D' as the real world.the games aren't 3d per se but certain things stand out more.
If you already have an nvidia card and a 120hz screen, then it's not too expensive but if you're just buying the screen and/or nvidia card on top then it's way too expensive
There's an FPS drop too, it's the sorta thing you need to try yourself really
