Right, but without direct voltage control of the panel, the AMD GPU cant effectively combat flickering or ghosting, which means Gsync currently has better control of the panel resulting in a wider control range and less ghosting.
That is the purchasing choice currently available.
You just made that up ^^^^, there is nothing that the G-sync Module does the isn't done in Free-Sync so now your just making stuff up.direct voltage control
Would you like to explain "direct voltage control" "voltage control of the panel"
