NVIDIA RTX 50 SERIES - Technical/General Discussion
There we go, first case of melted power cables with the 5090
That did not take long at all; so few GPUs in the wild and already cables are melting!
MFG is just a feature you can use or not, it doesn't matter at the end of it, the game is still the game, just like using x2 frame gen on other cards. Doesn't change the actual game if it's a well developed game..
But you could make that argument for many things. Why buy a 4 figure graphics card instead of a 3 figure one. Doesn't change the game if well developed.
I saw too many 4090 repair vids on youtube to want a 50 series pulling more power tbh. At this rate these GPUs will need specific PSU standards per model to ensure cables and PSU unit are good enough.
melted cable adds should be put up on those auction sites along side the 5090 listings, make the scalper sweat!
Time to get the popcorn out, chaps. Here we go :D 600w through a single flimsy connector. How stupid do you have to be?
Not saying there isn’t potentially a problem with the connectors again, because it’s too early to tell, but it is entirely possible that they were reusing the cables over and over again while swapping GPU’s around to do their reviews.
Wasn’t that a known problem with the previous cables too? Connecting and disconnecting them repeatedly increased the risk of failure?
Well yes it does, a lower end card isn't going to get the baseline performance to yield suitable input latency before the tech is enabled to yield a good experience, aka the whole situation when Frame gen came with RTX40 series and the whole hate for "fake frames" came about because the experience is only decent with a 4080 or above and now people will go through the whole cycle again once the 5070 and lower stack are released.
That's just FG, add path tracing into the mix and the number of cards that can give a good experience on that are just as small generally.
it's been updated. It was the 4090 so that's fine as the 4090 is gpu Jesus.
I can't remember who it was, but they showed the temp reading at the connector when idle and under load - it's just mental that Nvidia stuck with it.
Seeing a few people online posting about clock issues on the 5080 where the card gets stuck at a lower clock speed.
I've just had the same with mine with the gpu boost clock stuck at 2300 but after a reboot it goes back to hittings 2800, anyone else noticed this?
All the reports I've seen so far say its always fixed with a reboot.
Both sides (on PSU and card itself) have very limited lifespan, always had. But that also means any time one unplug it at home it increases the risk of failure considerably. Not a good design!
Or perhaps, and this is purely MY speculation, hold off for a year. Because with the reception the 5080 has had, a Super / Ti might come sooner than people think.
Let's remember this is Nvidia, we should never be surprised at what they do.
Probably a 5080Ti, There's too much gap between 5080 and 5090, not to mention 16GB VRAM only. It's crying out for a Ti launch. If a super comes out it will be a (nearly) whole gen relaunch like it was for the RTX 4000 series. The 5090 won't get another version, but the rest likely so. First the 5080Ti in about 6-9 months, then 5060s, 5070s, 5080s, each being 3-5% better than whatever is best version prior.
If we are seeing 1 connector melt out of all 8 5090s that were sold then those are some strong odds :eek:
People will be quite meticulous about how they insert the plug. PCIe 5.1 spec helped but didn't make it melt proof. Probably a few dozen kids will melt the socket on their 3 grand GPU, then post it on Reddit. ;)
