- 24 May 2015
They're not framing it like that though at all. Numerous times Reddit users say something like "I thought only the connectors changed, not the cable" *clearly* talking about the spec change. Someone from Cablemod will directly reply "Oh there were some minor changes to the cable, buy our new 12V-2x6 cable". They also seem to be telling people they should buy the new cable for 50 series GPUs.^ that’s not ‘wrong’ though. They are just saying “don’t use cable 1, use cable 2 - because it has improvements”.
That’s not going quite as far as Moddiy who did say ‘the specs have changed because of the new standard’ - that is the bit that’s BS.
In the Reddit thread you posted, they do generally stick with ‘use cable 2 - it’s better’.
I agree that does get a little murky when they say ‘Nvidia recommends using cable 2 with 50 series’ - have they? I’m not sure they have… publicly, at least.
Was all of this confusion avoidable? Undoubtedly, yes.
Clearly this is deliberate misdirection. Exactly the same as MODDIY. It's fine to iterate on your cable and add some improvements but stop pretending your newer version is part of the 12V-2x6 spec. It's really dishonest.the new RTX5000 series cards should use a new 12V-2x6 cable instead of an old 12VHPWR one
