NVIDIA RTX 50 SERIES - Technical/General Discussion
Seen a 5060 review, not bad but can understand why they not putting more vram on since they want those getting into ai stuff to shell out more.
12gb 5060 I'd have been ok with for ai photo and video editing
Just started actually gaming on my Astral OC 5090 and I honestly thought it was going to either take off or blow up.
The fans, and the top fan in particular sounds like a bloody jet engine. No way I could live with this.
I searched online and saw others complaining about the same and suggesting flashing the new “quiet bios”. I tried this but am I right in thinking I have to use GPU Tweak to adjust the top fan?
Not great for the price paid. I’ve bought ASUS GPU’s previously and I’ve never heard something so loud to the point my wife couldn’t hear the Hoover because of it, with the exact same fan curve I always use.
Sorry if this has been discussed previously.
You can edit the 3 front fans curves and the rear one separately in gpu tweak. Just limit the rear to around 1000 rpm for example.
'Fan Control' software also good for this.
Asus quality alright
unacceptable for a ~£3000 card, and the LC version has persistence pump noise issues not yet fixed from the 4090 lc version.
Nvidia has released new firmware for the RTX 5060 and 5060ti to "fix" the black screen issues
high prices, black screen issues, driver issues, melting connectors lol Nvidia the more you pay the more you save.
if AMD had released a card comparable to 4090 in performance or close to, I would not even think about buying Nvidia or a 5090 for even 1 second.
I’ve had a play around with this today and after flashing the new quiet bios and tweaking the fans in GPU Tweak I’ve found that the top fan is the issue. I’ve dropped it down to around 45% and it’s much more acceptable.
This is what I get for FOMO :)
I’ve heard a lot say this. Mainly due to the 4th fan, that incidentally also has little to no impact on temperature. I think a recent bios update helped.
Why would you use the same fan curve with a new card?
Firstly turn the quiet bios switch on (next to the power connector), then flash the quiet bios, next undervolt with Afterburner which is better than Asus GPU Tweak (0.895v & 2827Mhz). Also you can get +3000 on the memory if you download the Afterburner modded profile (google it).
My card is silent and tops at 65c / 850rpm fans
If it's still noisy you might have issues with case cooling intake and exhaust, if lack of airflow is causing the card to get too hot.
Also the top fan is linked to the bottom middle fan so it can't be controlled independently - they all run at the same speed.
I’ve used the same fan curve for years because I’ve found previously that the noise is a no issue and temps are great. Why change it?
I’ve already installed the new “quiet bios” as stated in my response to someone else on here and tweaked the fan (middle/top) and the noise is under control. Temps were never an issue either with this card, just the noise and it’s been confirmed by others.
Example -
Well if you're going to insist on using an old fan curve from an old card, that isn't suitable for your new card which has more fans and runs hotter, then there's little point asking for help here.
To clarify you need to undervolt and have the fan curve on auto. Alternatively you got a duff card like Debauer and should RMA
