NVLDDMKM display driver possible fix
14 Nov 2007
I have managed to stabilise my system after suffering with the "display driver stopped responding" for a couple of weeks.
I cant say its a proper fix, but my games run OK again.
I basically ran Registry Mechanic to fix errors and installed EVGA precision to give me the option to tweak and down tune my graphics core and also increase the fan speed. If i can keep the graphics card temp at about 55 when idling and no more than 75 when gaming its ok but if it creeps up to near 80 i know i will get a black screen and poss freeze.
I also removed 2 sticks of my memory and although i tried to put them back i got a BSOD.. i will check again after i am sure the sytem is stable.I It could be my graphics card is on the way out but i cant test it myself so i will have to live with it for now.
Anyway if this info is any help to anyone good luck and thanks for all the advice given to me to help with this insidious grapics problem (NVLDDMKM)
Sychnant
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
OCZ 4GB (4x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2
EVGA GeForce 8800 GT 512MB Superclocked "Crysis Edition" GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (512-P2-E802-AR-CrysisUK)
HD 1.Western Digital Caviar SE16 500GB SATA-II 16MB Cache
HD 2.Western Digital Caviar SE16 500GB SATA-II 16MB Cache
Pioneer DVR-112DBK 18x18 DVD±RW IDE Dual Layer ReWriter
Lian-Li PC-7 PLUS II Aluminium Midi-Tower Case - Black
Corsair HX620W ATX2.2 Modular SLI Compliant PSU(CMPSU-620HXUK)
