** NZXT H440 - SUPER SLEEK GAMING CHASSIS WITH EPIC WC POTENTIAL **
I zoomed on the images and it looks like thin rad, considering the motherboard mounting.
Full size motherboard will completely fill the interior, with maybe 65mm on top for the rad.
That being said, if you decide to put a thick rad in front, you can probably forget about 2 x 360 rads. That would be 240 max on top.
Things like this should really be in product description :/
From what i've heard you should be able to get a 30mm max in the roof with a ~60mm in the front and have enough space. But putting a rad in the front limits the HDD bays.
It would be nice if the information was actually official though.
Probably you can fit 30mm which means slim line rads will fit.
That is good, I was eager to try new Koolance thin rads, now I have a chance :D
With this case I would probably go for thin 240 on top or AIO and some very thick rad in front.
It will be completely hidden by that wall anyway.
I was thinking of something like TFC Admiral or Alphacool Monsta with Scythe's typhoons.
I am just a little concerned about the airflow.
Might have to put my dremmel in action once again :-)
I wouldn't be surprised though, if NZXT released new cases built around this style, only with more airflow, and "performance" instead of "silence" based.
They're onto a winner here, with that lovely interior layout, and that PSU cover with led-lit logo. Don't think they'd pass up the opportunity to cater to different needs using that foundation.
Bearing in mind the H440 aims to be silent, one criticism is that the side vents on the "roof" are on the wrong side (window/user side) for that purpose.
There's always the H630 like I have, it's pretty similar.
What sort of rad configuration can you get in that without modding the case, just out of interest?
I've got an 800D and am a little disappointed tbh. To fit a 240 in the bottom properly you have to completely remove the drive cage and cut a hole in the base for a rad grill.
If you go with the Admiral it would be a shame its hidden.
any update on when exactly this will be available?
I've ordered mine from OC, so would be nice to know.
NZXT Website says end of Jan/beginning of Feb.
CaseKing(Germany) website says they'll be shipping them on the 28th Feb. I found another UK website saying it wont be shipped until April, which is a bit of a worry.
It'd be nice for someone at OC to let us know what's going on. It's seems odd for a company to not know when they'll be getting stock in. Unless they're not telling us because they know it wont be until late April, knowing people would go elsewhere to get it earlier.
Sorry if i'm coming across impatient. I'm ordering other bits off OC to build a new PC. Would be nice to know if I should just use my old case for now or wait a week or two for the H440.
