- 21 Dec 2019
- Planet Thanet
Here's jayz2cents on cross flow vs dual pass
Probably explains it better
Short answer basically much the same temperature wise
One thing with x flow /cross flow
Double check the overall length as having ports
At both ends may make it slightly longer
Not an issue in a lot of pc cases but something to be aware of
Thicker should mean better
Though again need to check case support once fans are fitted
Especially top mounted radiator ram clearance if got tall ram
Though 44mm is still a decent thickness
m.youtube.com
Edit
If you plan out your loop
In your head or sketch it out whichever you prefer
Should be able to see if in one end out the other
Will give you neater tube runs
Whether you use cross flow or standard
I would still recommend multiple ports to make life easier
Give more options
Crossflow vs Dual Pass Radiator... Which is better?
Use my link https://www.audible.com/JayzTwoCents or text JayzTwoCents to 500-500 to get a free book and 30 day free trial...Amazon Prime members who sign up ...
Edit
Give more options
Would be able to get through stuff easier if everything was written like that.
…but have built a few. But this technique basically ‘proves’ when the radiator is clear of specks.
