O2 Dropping out recently?
18 Oct 2002
Cheshire
Installed about 7 months ago and been perfect for 6 months, but just in the last month or so it's been dropping out every now and then. Anyone else been having the same problems or is local to me?
In what sense is it "dropping out"? If it's losing sync it's something local to, at most, your exchange if not your line.
You need to actually be sure. Lights will go out on the router when it loses sync, and there'll be some indication on the router...
had the same problems today for first time. 06:30, in the middle of working from home, the connection dies.
The router control panel said something about "looking for DHCP server" or something.
Funnily enough, just happened whilst I was replying. I'd say it happens to me a few times a week. All the lights on the router go out for a few seconds, even the power one (it's not a power cut!).
I was having a few issues with 02 yesterday disconnecting but i swapped the filter and changed to the 02 router and that seemed to fix it. It didnt stop the issues of Day of Defeat losing connection yet i was still connected to the internet.
An here's the event log for today, it was working last night at 00:10, then i've come home from work today to find the router is on, hasn't rebooted but the internet connection is dead:
Warning Nov 24 17:14:20 DHCC intf O2_ADSL2plus renews lease ip-address 94.192.***.**
Warning Nov 24 15:44:21 DHCC lease ip-address 94.192.***.** bound to intf O2_ADSL2plus
Warning Nov 24 15:44:20 DHCC intf O2_ADSL2plus rebinds lease ip-address 94.192.***.** from server (82.132.253.112)
Warning Nov 24 11:14:21 DHCC intf O2_ADSL2plus renews lease ip-address 94.192.***.**
Warning Nov 24 10:29:21 DHCC lease ip-address 94.192.***.** bound to intf O2_ADSL2plus
Warning Nov 24 09:44:21 DHCC intf O2_ADSL2plus rebinds lease ip-address 94.192.***.** from server (82.132.253.112)
Warning Nov 24 05:14:21 DHCC intf O2_ADSL2plus renews lease ip-address 94.192.***.**
Info Nov 24 00:19:11 SNTP Synchronised to server: 87.194.255.135
Info Nov 23 23:21:48 LOGIN User SuperUser logged in on [HTTP] (from 192.168.1.66)
Info Nov 23 23:21:00 SNTP Synchronised to server: 87.194.255.139
Is all the ip lease renew/rebind the cause of the problem? As in it doesn't appear to have rebound the ip on the final attempt.
Bit more info, doesnt look very good:
Uptime: 0 days, 0:43:41
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,278 / 11,582
Data Transferred (Sent/Received) [MB/MB] 4.96 / 163.92
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 19.0 / 36.0
SN Margin (Up/Down) [dB]: 6.5 / 6.0
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 27 / 0
FEC Errors (Up/Down): 4 / 12,149
CRC Errors (Up/Down): 4 / 20
HEC Errors (Up/Down): 9,056 / 10
Eh? Nothing wrong with those, you could push your line 2-3 meg faster if you dropped the snr (cant do that with o2 though). Looking at my f8lure graph I've had a good 6/7 chunks of packet loss today but my modems not dropped once. Depends on how good your box/firmware is, Bes has had stability issues so I assume O2 has too.
Uptime: 6 days, 9:03:22
Bandwidth (Up/Down) [kbps/kbps]: 1,386 / 14,005
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 0.00
Line Attenuation (Up/Down) [dB]: 20.0 / 37.5
SN Margin (Up/Down) [dB]: 3.5 / 1.0
Error Seconds (Local/Remote): 110 / 0
FEC Errors (Up/Down): 1,168 / NA
CRC Errors (Up/Down): 1,168 / 44,260
HEC Errors (Up/Down): 7,124 / 23,816
Rock solid connection, although it seems there's a much lower limit on the fec count this new firmware does :(
My connection keeps dropping in the evenings as of late. It's so frustrating. It's been dropping every night for the past 3 or 4 days or so. Perhaps it's the weather conditions or something, I don't know. It seems more like a DNS error though; e.g. Facebook chat will continue to work, I can still stream off iPlayer and indeed Spotify but every website seems to refuse to load!
