- 22 Mar 2009
I just brought 4ghz bundles with new Antec 1200 Twelve Hundred Ultimate Gaming Case because I took it back to overclockers as Rich had sorted out my cpu cooler not seated correct and temp went too high over 90C+ as he advise me to get a good airflow tower case as this is the main reason I had brought a new Antec 1200 Twelve Hundred Ultimate Gaming Case to fitted the motherboard on it.
I got serious problem now with my parts here:
Core i7 920 D0 4.00Ghz
Patriot Viper 6GB 1600Mhz at 8.8.8.24
Titan TTC CPU Cooler Fenrir
Arctic Silver 5 Paste (Rich had sorted it out for me)
Gigabyte GA EX58-UD5
Corsair toughpower 750W pwer supply
Geforce 260GTX x 1 (at freq 101)
DVD-RW Writer x 1
Samsung spinpoint F1 7200RPM 1TB Hard Disk x 1
The pc run at idle at 54C 4.00Ghz but full load at prime95 after 5 minutes the temp was reading at real temp 3.00 is 96C (too high)
Run flight simulator X and load the game, after 2 minutes the pc freeze and stopped but temp reading at 81C with around 25% in use. Graphic card temp is 47C.
I turn off 4.00Ghz and go back to 2.66Ghz and flight simulator X with temp at full load was normal under 70C after 30 minutes using prime95.
I don't know why is not stable and why is temp run over 90C+ with full load as couldn't playing flight simulator at 4.00Ghz ?
I thought the tower case is great airflow as all cable management cables, wires was hidden in the back side of the case leave all motherboard very clearly and space for a good airflow.
What can I do next ? I was disappointed as I thought Rich advise me correct of buying the good tower case with good airflow but compare to my old tower case, it still the same, no different to flight simulator x freeze and temp went too high.
Very disappointed and really annoying. Spend £540 on the bundles and spend £138 on the new tower case.
I kicked myself of wish not purchase it all in the first place and just forget the 4Ghz bundles.
DVD-RW Writer x 1
... Probably depends if the bundle includes a retail processor or an oem one.
