I hate the shroud on the XT, who on earth decided on that as a good idea, looks like it's melted from overheating.
Haha, that was my first thought when i saw it. It looks ridiculous.
It seems to run hot, so maybe they are pre-empting the melting
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
Navi disappoints on many fronts performance wise, its a mid range card at best. price point is ok but it gets beaten by the 2070s in most but a few games. the VII remains AMD's top card to date. this can be seen as a vega 56 vega 64 replacement with quite a small considering 2 years later performance hike.
over all its no NV killer.
Goes against what others are reporting. Need to see this in action.
https://adoredtv.com/amd-radeon-rx-...aphics-card-review-bringing-competition-back/
https://www.guru3d.com/articles_pages/amd_radeon_rx_5700_and_5700_xt_review,8.html
Just to point out a couple.
Only had a quick look but at 1440P faster than a 1080 Ti in a few cases. I'm not a fan of the "fine wine" talk but they can probably improve them a bit further. £120 less than some want for a used 1080 Ti (£500). Doesn't seem so bad to me for a brand new component with no quibbles warranty
Hot, loud, underpowered
Not again AMD!!!
5700 XT seems good so far over VEGA 64 tbh. It wins and looses some against the Super 2070 and even at times comes close to the 2080 and beating Vega 7.
That's very true.The 1080Ti is two years, and 4 months old!
92C!
Guru's review also has it throttling.
Ouch.
5700XT is about what I expected.
Thermal/Acoustic side a bit poor though.
Vega is a lot better with a simple under volt, hopefully the same will apply. If not, then, custom cards will be the only option unless you are water cooling. Also, there doesn't seem to be much overclocking headroom.
The 2070 Super is definitely the way to go.
Ay? You not read it correctly?
The XT is reporting its correct clocks.
The XT version is 1850x~1900 Mhz and also actively throttling based on limiters."
So you'll have to make the card even louder to keep its clocks stable. That's not really great lol.
If it was a 175W part my opinion would be different.
100% shocking tbh it just makes them look stupid when all other sites are reporting very different results.Techpowerup is an Intel/Nvidia shill.
Can't see why AIB's will go crazy with the 5700XT, given it's a mid range GPU.
