51 x multi!That's the highest multi that these Sandy Bridge board go up to? 99?
Max multiplier is 57 I believe. Who'se going to be the 1st to risk 6GHz? (Joking, dont!)
Well done mate, what is the max that you can pass 3d vantage?
Looking good Simon.
Are you running with HT enabled for your Prime/IBT tests?
Do the sandy bridge motherboards do 16x 16x?
However i'll b going back to 1.35v and 4.5ghz for the time being. 1.42v wouldn't get me to 5.0 and even thats too high for my liking. This was literally a 1 minute bump up test and back down.
isn't 1.45 a bit high on the voltage side? What can these chips do in terms of safe volts?
.Nope. LGA2011 for that I believe.
Though I'd bet you'd hardly see the difference between 16x 16x and 8x 8x anyways.
The other major (and welcome) change is the move to PCIe 2.0 lanes running at 5GT/s. Currently, Intel chipsets support PCIe 2.0 but they only run at 2.5GT/s, which limits them to a maximum of 250MB/s per direction per lane.
I thought the max these chips would take was 1.38v? You guys are playing with fire there! That'd be like me pumping 1.6v through my 965BE.
