7 Mar 2013 at 22:25 #1 Cpute Cpute Associate Joined 17 Feb 2013 Posts 129 Location Mistley, Essex Does anyone know how i set an SSD up to in AHCI mode on windows 8 I've tried the regedit msahci attempt but i have no such folder any suggestions? :/
7 Mar 2013 at 22:28 #2 Uncle Petey Uncle Petey Soldato Joined 22 Jul 2012 Posts 16,222 Location London You should be able to set it in the bios unless win8 is even weirder than I thought
7 Mar 2013 at 22:41 #3 Cpute Cpute Associate OP Joined 17 Feb 2013 Posts 129 Location Mistley, Essex Tried that no option to, the bios hasnt changed from when i had win 7 though still same one awith my mobo
8 Mar 2013 at 02:11 #4 marc2003 marc2003 Soldato Joined 6 Feb 2004 Posts 20,921 Location England Cpute said: I've tried the regedit msahci attempt but i have no such folder any suggestions? :/ Click to expand... you only do this if you installed windows with the bios in IDE mode and you need to change it. sounds like the bios was already in AHCI mode before you started this windows 8 install? it should already be AHCI. check in device manager here: if it says something like "standard 1.0 ahci controller", you need the latest chipset drivers for your motherboard.
