Hi ive just installed a Vertex2 and when using Crystaldiskmark my read.write speeds are way below the specs.
However when using Atto my Read/Write are correct,is the sandforce controller not really configured to work with crystaldiskmark as my old C300 was fine,though it used a different controller?
Should i use Atto and ignore the low benchmark speeds with crystaldiskmark?
Edit:
My Write speeds with Atto are only 150mb when they should be 275?
It seems after more research using several benchmarking programs which i have done tonight, might slow down the write speeds so i will have to check again in a few days.
Edit:
