Hi Guys
First of all thanks for helping an idiot over the years, its very much appreciated, to be honest its the sole reason I wont shop anywhere else (obviously no direct link to the store, but the its down to their forum so figure its only just to keep the money going to an area where im helped!)
Following on from the thread I posted in March 2013
Motherboard and processor remain the same, tweaked a few quick fire wins i.e. graphics card and memory
This computer seems to be doing well but I seem to have this itch to upgrade what is an 6.5 year old processor and motherboard!
My primary use is gaming, seems to still perform well barring the odd hiccup with tearing in certain games
Currently running:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66GHz (Nehalem) (Socket LGA1366) (Clocked at 4.1GHz)
Asus P6T Deluxe v2 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Be Quiet! Dark Power Pro 850W ATX2.2 Modular SLi Compliant Power Supply
Corsair CMZ12GX3M3A1600C9 12GB DDR3
Graphics card is obviously a more recent purchase and is fine
ASUS Radeon HD 7970 ROG MATRIX Platinum 3GB
I run games on a single monitor at 1080 resolution (reason for this as its a
Samsung S27A750D 27" 120Hz 3D Widescreen Ultra Thin LED Monitor
So same question if i could
Am i actually going to notice any improvements? Or just hang fire again?!
I just upgraded from amd 8320 to an i7 5820k and my minimum fps has more that doubled eg 30fps to 65fps in project cars. So i would look at your minimums first before deciding. Your gfx card is quite old too to it might be better to upgrade that first. What fps do you currently get in games?
Yea but you can't compare Intel with AMD chips. Even an i3 is quicker than the "high end" AMD cpus.
I'm in exactly the same position...
I have an 920 and a 7970 card. For years now I've been saying 'I will upgrade my CPU'.
Started with Ivybridge- disappointed because no solder. I'll wait to ivy-e. Oh, no solder. OK. I'll wait for haswell.
haswell- no solder. haswell-e underwhelming.
It's been a long time coming, but broadwell-e seems to be the one. As long as it's soldered and decently priced. New cores, die shrink. Same with next gen graphics. Now is the time to upgrade. People saying wait til skylake. Why? Seems like a meme to me.
Same advice, get an x5650 and a new gpu like a fury nano. Would be a solid upgrade.
The benefits of an X5650 over an i7-920/930 have been explained numerous times in this thread. Yes of course you can upgrade your entire system instead but it costs way more and not everyone wants or needs the extra benefits that comes with such an upgrade.It seems to be a theme here to recommend out of date technology...
No thanks, I'll actually use my brain! Next gen graphics will be a huge leap in performance and worth the price. 920 was fine, but broadwell-e is definitely the time to upgrade.
