Only one fanon AIO cooler lights up
22 Nov 2007
Hello
I've been playing around with the rgb settings and have noticed only one fan from AIO cooler lights up. Any ideas?
The PC is a pre built from OCUK
It's not quite clear what you're saying. So did you go through the settings in Armoury Crate because of this, or did this happen after you'd been in there?
can’t say for sure as i’ve only had it for a few days. Just noticed this afternoon that that every fan is green apart from the two as shown in the pic.
It's possible they're on a different RGB header to the other fans. Were they green before you started playing, or were the other fans blue by any chance?
Right, just seen a pic i took on thursday and they were all green then. Maybe playing around in armoury crate has messed something up?!
That would be my guess. If it's anything like the Gigabyte cancer I'm using, you can click on each RGB connector on the board and set the colour. If one of them's showing as blue, that would be your problem.
It's also possible OCU used a separate RGB controller, so I'd definitely give them a call if you don't get anywhere with Armoury Crate.
