- 22 Nov 2007
Just going through the settings in Asus armoury crateAlthough tell us more about this 'playing'..
It's not quite clear what you're saying. So did you go through the settings in Armoury Crate because of this, or did this happen after you'd been in there?
Right, just seen a pic i took on thursday and they were all green then. Maybe playing around in armoury crate has messed something up?!It's possible they're on a different RGB header to the other fans. Were they green before you started playing, or were the other fans blue by any chance?
They were all green on thursday so i don't know whats happened. Now the two that aren't green don't light up at all...
In a few days?Leds can fail
That would be my guess. If it's anything like the Gigabyte cancer I'm using, you can click on each RGB connector on the board and set the colour. If one of them's showing as blue, that would be your problem.Right, just seen a pic i took on thursday and they were all green then. Maybe playing around in armoury crate has messed something up?!
In a few days?
Thats a bit crap. I mean i can live with it but its annoying.Yup.
I don't have any ARGB, but can you not uninstall/disable Armoury Crate and try a 3rd party controller like SignalRGB?
But with it just being the 2 fans going wrong it probably is best to contact OCUK and make use of your warranty, it may be something simple that they can talk you through.
If you are using Windows 11 this can also take control of your RGB, have you looked at this at all?
