- 6 Sep 2016
Would make sense once you find out if it's a specific fan, or two they just send you replacement fans and change yourself.
sounds like a good start, now to disable the rest of them!
Its not silly you are annoyed, you paid for something that is not working correctly or started to have issues a few days later.Starting to think i should lol. I mean what a stupid thing to get annoyed about but i am..
yeah true, it did cost a lot so it shouldn't be failing so soon.Its not silly you are annoyed, you paid for something that is not working correctly or started to have issues a few days later.
I just sent back a 4070Ti which I disabled the RGB on as I hate it. recently, the RGB will randomly come on and start to flicker like mad for a random period of time and then go off. With a windows side case (Corsair 4000D) it drives me mad as its so off putting)
I could take taken the back plate off and unplugged the cable but when I got it at release for (March 2023) £830 there is no way I am putting up with it due to the amount it cost and regardless of if I use it or not I want it "fixed" lol
Not too sure, I sent it back yesterday and they confirmed its arrived today. I think they have 30 days to fix it or send it back to the manufacturer to sort it.yeah true, it did cost a lot so it shouldn't be failing so soon.
Oof yeah that is annoying. Wonder how long you will be with out your gpu?
30 days lolNot too sure, I sent it back yesterday and they confirmed its arrived today. I think they have 30 days to fix it or send it back to the manufacturer to sort it.
Unsure what's going to happen with it as the 4070Ti was replaced with the 4070 TI Super model and this is no longer available.
The GPU worked fine and it was just the RGB that was having issues.
Spoken to OCUK about the system yet or still troubleshooting?
I would be calling them to find out what's happening with it if its been that long!30 days lol
I sent my sapphire Rx6800 in in mid November.
Not a peep.
hopefully you get sorted out quickly. Na haven’t called yet, busy day at work and then i played cyberpunk after. Will call on FridayNot too sure, I sent it back yesterday and they confirmed its arrived today. I think they have 30 days to fix it or send it back to the manufacturer to sort it.
