Onwards and upwards by Parvum Systems
Beautiful and inspiring, I can find no other words to describe it.
Well done everyone @ Parvum, such a build should be placed behind glass on display somewhere.
Oh while I remember I have a little acrylic related question for you, what speed should I be drilling 3mm thick sheets at and are regular hole saws ok to use? I'm guessing around 4-500 rpm should be fine I just don't want to crack it. Given my job, its quite ironic I haven't got a clue what speed to use, I could tell you how to cut most commercial metals under the sun but plastics I'm lost.
Also is it easy enough to shorten down a sheet by running a blade down the desired cut line then just bending it to snap off?
I can't help but feel it would be better without the text on the side. But that's just me...
Otherwise it's a testament to what Parvum can do - looking forwards to getting my own S1.0 to play with.
And may be in touch about some extra metal cubes to mod the case with (if that's possible)
Been a pleasure watching this take shape - some truly inspiring details and workmanship
Wow real nice build. That watercooling is just excellent and the colour scheme is great.
However, imho the fans are a bit flashy and over the top, I would prefer if they were less glossy and understated. But hey, thats just me.
I keep popping back in here to check for updates thinking nothing can make it any better. How wrong I am every time. Keeps on improving, great job sticking to clean design and aesthetics that are stunning to look at.
HOLY BATCRAP!
stunning, simply stunning! you should put this up for auction or as a competition prize. or just keep it tbh as its just fantastic
Definitely something we will consider doing. Will be holding onto it for the summer as it will be on display at a number of LANs/events. Until we do another project this one will be our little baby!
Thanks for the kind words.
As for the drilling. What kind of hole size are you trying to cut? Obviously as we have access to CNC we would CNC all holes using our standard single flute cutters. If we where to do it by hand I would advice trying a couple of options. Spade bits are much better than hole saws from what we've found. It's important where possible to clamp the material really well & if you can have something underneath at the cut through point to avoid chipping towards the end of the cut. 500 RPM is a pretty good place to be with acrylic.
It's more about the plunge than the RPM. You just have to go incredibly slow and let the drill do the work.
Report back with your results!
Yeah it's always the thing with branding. We knew to a lot of peoples tastes simple clean acrylic can look nicer and give a more elegant feel but we wanted this one branded up for ROG. We've used ROG equipment from the start so this was a props to there amazing hardware.
We can sort some extra cubes out for you yeah. Email us your address to - [email protected]
Thanks for the kind words. Understandable on the fans. The clusters can be like Marmite we've noticed on the internet. We've used them in most of my builds and still love them. Other than the water block LEDs these are the only light source in the build and the subtlety of that kinda makes up for it. We almost went with some matte white fans but didn't find 80mm versions.
We grew to love the gloss of the Enermax in this build as the paired nicely with the gloss in the acrylic tubing.
Wow cant belive im only just coming in to look at this, its beyond awsome! Nice one :D
looks awesome
Wow, just wow!!
Wow man...
That is some fine work!
REALLY well done.
one word AMAZING!
I WANT IT!
Think there needs to be a new word invented to describe this build because all the other typical ones wont do it justice.
Its just........ :eek:
uhhmazingggg
I have rated this thread 5 stars.
I think others should do the same too. :)
Just wow.. :)
Thank you all so much. We are super happy to be a part of the forums here and hope this will help everyone understand more about us. We are as you may now know just two young modders/enthusiasts trying to compete in such a massive industry already full of quality and amazing products. Its extremely difficult for us to compete but with the help of everyone in the modding scene hopefully we can continue to push our products.
We just want everyone to know that there input and ideas are always SUPER welcome. We urge you to drop us a line at [email protected] if you have any ideas and input. On top of that if you are ever slightly unhappy with a Parvum product we want you to contact us straight away and we will put it right. The beauty of our cases is that they are fully modular. If you feel a certain panel or part has a finish or an edge you are not quite happy with; please let us know!
Again massive thanks for the support along the way. Expect a new ITX project log to be up soon!
Superb build guys, I really hope I win your giveaway!! Hopefully my CAD skills will be up to doing something similar one day.
We will be announcing the winner very soon! With an overwhelming amount of entries and response we will be running a second comp very soon!
Having just built my first watercooling loop and experienced first hand what it takes.....
That is beyond stunning. If i was to allow you to abuse me in some devlish act of perversion would you let me have that? Or maybe my first born would be prefered?
It's this type of case company that makes me smile when I see them communicating with people well, taking all comments and questions in their stride.
You guys do an excellent job! Keep it bloomin well up!
