Onwards and upwards by Parvum Systems
I like that idea.. I like it a lot! :D
So a close friend of mine actually draws and tattoos some of the best reapers ever. Que an awesome etching into the case window...
i think im slightly in love with these cases.
Same here though I'd never be able to build something as neat looking as this.
Thank you both. Kaktus I think you would be surprised when you use one of our cases. With simple cable extension kits the layout screams to be ultra clean :D
I got to say that case is just something else. i would buy something like that in a heartbeat. Soo clean and tidy
very good job
Great bit of engineering there.
Thank you all. We would love to be able to reproduce something like this but it was defiantly a personal project with a lot of stress. Unsure if we could do it again haha. 8 Pack however has some awesome stuff up his sleeve coming soon :D
Your case just look brilliant...
Please make some Midi Tower case and I will be the first who buy from you!!
We are bringing out the ITX case next. True ITX however, I really small SMALL LAN box but with some good W/C potential. ATX case will defiantly be closely following!
Looks amazing :)
Thanks!
Great build but I think the braided cables could be tided up in that there is no cores visible crossings..I'll get me coat
No without a doubt, it was one of them things that you only see in the photos when it's too late. If we get a good day I'll straighten everything out before the show event. Also GPU backplates would have gone from being an epic build to a perfect build.... :D
Hi guys, can you give me a price on a clear smoked perspex front panel? Not the "X" panel but the panel behind it? Where you mount the front fans. Also maybe a logo cutout into it as well. Pm me for prices please if you dont mind :).
Also did you get my e-mails? Thanks for the replacement parts and gift! It was a really nice surprise!
hey Parvum.
the S1.0 case, Can the Top and bottom pannels be swapped? So that the case can be turned upside down to be Flipped ATX?
I want the window to face the right and see the GPU block.
After looking at these cases, I have to say i'm in love. Why doesn't someone do a 'Noctua version' so to speak? ;) Creamy-ish and brown? I think that'd look awesome. I'm thinking of doing it for my next build as I think every fan I have is a Noctua haha! :).
Quick question though, I've seen quite a few builds in this case now and can the internal dimensions of the case support a 360mm rad? I know 8pack did one but I think I remember him saying its slightly longer but there was still quite abit of room left over.
Great work tho guys. The case is amazing!!
What features have been added to the S2.0?
It's basically a revision. Demand is very high for the 1.0 still but we wanted to add a few essential changes. USB 3.0 will be as standard in the front. We have changed the panels to create a built in case feet system. This is pretty damn useful when a lot of people our moving their rigs. We pulled the height of the case up by about 15mm in size, again super helpful to squeeze that extra thickness and have more freedom with radiators. Finally we changed the clear window acrylic to a hard coated acrylic. This is super scratch resistant and we are very happy with the gains.
Great stuff! I was looking for a custom case to be built, and the extra height and USB 3.0 were 2 of the things I was looking for so that's brilliant. I emailed about a custom build but you said to try again in February so i'm hoping you guys could make me an extended S2.0 that will accommodate a 360 rad up top, along with the 240 at the front (with no radiator at the bottom as i'll be installing dual r9 290's) :)
I have pretty much all of my hardware to go, just require a 4770k and the case. Will be using red/black braided cables, matt black monsoon fittings (13/19mm) and tygon tubing with mayhems pastel red coolant. Should be a squeeze but i'm sure it'll look good :) Would be more than happy to take some photos if you'd like to showcase it on the site when it's built :)
