Optimizing System
The fans HAVE to be bottom right on that pic and the HDD's cant move.
Can`t you put the 2 hdds in the bottom rack and remove the central rack? Then put have 2 fans at the front, with the bottom one running a bit slower, should keep the hdds from getting hot. Then the top front fan will pump air straight across your Gpu.
it's a case.
you said you wanted to pimp the airflow/cooling - not really going to get more out of the components you have.
I wouldn't spend money though, don't think it's worth it... but if you want more... spend
it's a case.
The only things i can do is replace the cooler and the case?
What about another inlet fan on the roof?
There are far better cases around with better air flow. I'd do that rather than spend out on trying to fix up this one.
air should come in at the front/bottom and out at the back/top
adding another fan on the roof isn't going to do much, I'd be thinking more about removing the one that's there - gotta think about what direction that goes in and what direction the 920 goes in and see if they're fighting each other
I did remove it from the top as it was battling the 920, moved it to the front as another inlet. I would go for a new case but the 920 is a pain to fit.
Like that?
Like that?
Spot on mate. :D
Now you should see a difference in temps.
Cable management takes a bit of time for some of us, took me ages to get mine right. Now I am putting in a fan controller and a couple of more fans, so will have a couple of days next week to play around. If you don`t already have them, get some cable ties, makes it all so much easier.
