Ordering SSD for first time need help
Personally I would get this one instead
http://www.overclockers.co.uk/showproduct.php?prodid=HD-145-SA&groupid=1657&catid=2101&subcat=2102
or if you can find the extra money, one double the size for £90
http://www.overclockers.co.uk/showproduct.php?prodid=HD-149-SA&groupid=1657&catid=2101&subcat=2103
Reason being the Samsung wipes the floor over the AGility 3
http://forums.overclockers.co.uk/showthread.php?t=18368624
And even if you only have sata 2 (*it will still work) the samsung will just max out at 275Mb on the scores which are above it which still wipes the floor over the agility.
You were beaten like a ginger step child :p
yeah, speedyfingers mcgraw beat me to it!!:p
it might come with sata cable idk,but they are easy to pick up,might have a spare in your motherboard box if its a new build ect
as always with any ssd set sata ports to ahci mode in the bios before your installing windows 7,it gives you the best read/write figures
With it being the notebook verion, you don't get a cable however you save a fortune compared with the desktop version which comes with one. Apart from that the drives are identical.
You don't get a 3.5" drive plate adaptor either so you can fit it in your drive bay. These are only three quid but ssd drives are so light you can just velcro them anywhere (which is what I did)
