OS PROBLEM ... PC WON'T BOOT to W7
13 Nov 2008
Hello,
I had 2 partitions on HDD 1st partiton was VISTA and I insalled W7 on second!
As I found W7 better and no way going back to VISTA I formated 1t partition with Vista!
Since that PC won'tboot W7 and saying : BOOTMG IS MISSING something like that!
any help will be appreciated!
Thanks
Snake doctor & valo are right. It isn't anything to do with the boot order of the HDD, you have wiped the bootloader.
Either one of their suggestions should work. I personally use the command prompt but it makes no odds.
Good luck
