I have overclocked my E8400 to 4.05Ghz with a TPower I-45 and 4gb XMS2 800Mhz ram. This is housed in an Antec 300 with 2 intakes and the stock exhausts on medium setting and I have a Titan Fenrir on the CPU (exhausting out the top).
To get the overclock I have done the following:
Multi - 9
FSB - 450
Ram - 900
Vcore - +0.025 = 1.33ish
My idle temps at average room temps are 42c on Core0 and 35 on Core1. After 9 hrs of Prime small FFT the temps got to 49c on both.
So here are my questions:
1. Is it normal to have such a difference between the two cores at idle?
2. Do my temps seem fine to you guys? I know they are a reasonable level but I expected a higher temp during Prime.
Thanks
Multi - 9
FSB - 450
Ram - 900
Thanks
