*******OVERCLOCKED**OCZ 6GB Tri-Channel @ 1800MHz OC £69.99*******
I've got 12GB of this stuff 2 x 3 kits going at....
1560mhz!!!!
9-9-9-24...etc 1.64v on Asus P6T Deluxe.
thanks for the amazing 12GB deal you ran last week!
edit, wasn't even sure I'd get stock speeds with 12GB...very chuffed :)
I tried a few more kits of these yesterday during overclocking the bundles and yet to see a set that wont do 1800mhz :D
Just a tip, when overclocking the ram make sure you increase the QPI voltage aswell, this is a must.
Yes You WILL!!!!! Yes You WILL!!!!! Yes You WILL!!!!! Yes You WILL!!!!!
:D
Thanks, you just saved me £40 for buying these instead of G.Skill 1600MHz.
if you had got the gskill - you would have regretted it - the ocz kit is far suprerior for overclocking
having said that, the gskill is great at stock and allows for timing adjustment
