1 Sep 2013 at 11:39 #41 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham 800mhz is right,you have to double it so 800x2=1600mhz
1 Sep 2013 at 11:42 #42 snips86x snips86x Soldato OP Joined 14 Nov 2012 Posts 17,998 Location Chesterfield wazza300 said: 800mhz is right,you have to double it so 800x2=1600mhz Click to expand... ahh ok. How could I get 1866 out of it?
1 Sep 2013 at 12:06 #43 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham tell me current timings/dram and vtt voltages
1 Sep 2013 at 13:16 #44 snips86x snips86x Soldato OP Joined 14 Nov 2012 Posts 17,998 Location Chesterfield wazza300 said: tell me current timings/dram and vtt voltages Click to expand... VTT is stock at 1.05v and the timings are 9-9-9-24 2T
1 Sep 2013 at 13:18 #45 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham ok with 1866mhz try 1.10v vtt and 10-10-10-28-1t timings idk how much dram voltage but maybe try 1.6v (dram is separate from vtt) if it fails change 1t to 2t and try again
1 Sep 2013 at 20:42 #46 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham did you get it to 1866mhz ram speed?
1 Sep 2013 at 20:47 #47 snips86x snips86x Soldato OP Joined 14 Nov 2012 Posts 17,998 Location Chesterfield wazza300 said: did you get it to 1866mhz ram speed? Click to expand... Thanks for the details. Unfortunately, I've been otherwise distracted and I will try and give it a shot tomorrow if I'm able to setup my 7970 with no hassle. Will report back once I've given it a go.
