- 27 Nov 2009
ok brb gonna have a go in bios now...
bbc i player i see... yes i know how to burn iso...ok i'll go and play call of duty modern warfare 2 then
ok great thanks for your help so far and i will see you later maybe if not see you tommorrow bye for now...
Edit
well it was DDR2-666 5-6-6-18 and now its DDR2-800 5-5-5-15yay was 5-6-6-18 now running stable @ 5-5-5-15
Were not quite overclocking yet, just getting the hardware to run at its *official* speed . . .sweet
my first overclock ...lol sorta....
lol ok thanks
Nice One Dan . .
The next step after (and only after) your sure the memory is solid @ DDR2-800 5-5-5-15 is to go back into BIOS and change the Memory Frequency down from DDR2-800 to DDR2-666, then you need to change the FSB from 333MHz to 400MHz, that will overclock your chip up to 2.8GHz hopefully while leaving your memory running again at 400MHz (DDR2-800) 5-5-5-15![]()
If this doesn't work then try adding more volts to you cpu voltage
never put more then 1.5 volts in to your cpu tho
