- 15 Feb 2009
- Bristol
Hey guys.
So i'm gonna be overclocking my E8200, with the PC in my sig.
Now i'm not gonna be doing this until next week somtime, but i have some prep to do and questions to ask
Atm, i have the Freezer 7 Pro and have it sitting easily at 3Ghz at default settings. Temps are about 39c idle and ~53c? full load with Prime95. Voltages aren't actually set properly in my BIOS, but haven't had any bad effects so i've left it like that since last year; vCore on 1v and one of the 5v settings at ~3.5v.
I'm hoping to overclock this thing to at least 3.4Ghz, hopefully 3.6Ghz+. So my first question is will the Freezer 7 Pro suffice?
I was thinking of getting a new cooler. Initially the Sunbeam Core Contact Freezer, but apparently according to frostytech's review, the Titan Fenrir is better. Anyone confirm this?
Would getting either of these two make a significant difference to help my overclock?
And which one should i go for? Because they are practically the same price this week, because of the weekly offers.
Edit: Would both of these fit on the MSI P35 NEO2-Fr without a problem? And small enough to fit inside the Antec Sonata III case?
I heard that the Fenrir is a bolt system, and not a push pin like the Sunbeam? Anyone confirm or is this wrong?
Before i start overclocking these are the things i need to do (which i'll check once i've done them):
Sort/manage/declutter hard drives - Check!
Reformat two partitions and install Vista 64-bit. - Check
Clean out PC and stick in a spare 120mm fan blowing down onto the mobo (doing this i don't actually know how; cba to drill into the side panel) - Check but no room for the extra 120mm fan
Manage cabling to ensure good airflow. - Umm check but not check..
Once all that's done, then i'll start overclocking.
Will be starting... sunday, latest.
This is what is looks like atm.
Any tips on cabling? Or anything else?
