Jokester said:Hot, hot, hot!
I've got mine Prime stable on water at 3.6GHz, but it's peak load temps are in the mid 70s. Mine did 3.1-3.2GHz or thereabout on stock volts without getting too hot though.
Jokester
Jokester said:It's because you've got 4 cores = twice as much heat as a Conroe. It'll be pumping out considerably more than 200W I would have thought.
Jokester
Jokester
Jokester said:Other people on water are getting the same temps, and note that's Coretemp temps not motherboard (so +10-15C).
PSU calculator says that it pumps out 240W.
Jokester
Jokester said:Water temp is 25C.
Jokester
Concorde Rules said:Well there we go then, the cores cannot get rid of the heat into the water quick enough, I'd bet that IHSless and the best waterblock could get that sub 60C![]()
Jokester said:I've already got the best waterblock and lapped the IHS to an inch of it's life.
Jokester
Concorde Rules said:Ah, but your not naked tbh![]()
.Would it make a huge difference though? Jokester has already said the water is at 25 degrees.clone said:The only thing you could do is fit a chiller or go phase if you want colder.
