Hey folks. I'm thinking of getting this mobo myself. Just a quick question - I notice in Graeme43's mobo prep guide that this mobo doesn't come with the correct BIOS for the Conroe cpu. Is that also the case with the Allendale (E6400) Core 2 Duo? As I have no way or knowledge on how to flash a BIOS, could I potentially be stuffed here?
Thanks.
edit: And if the supplied BIOS does work with the Allendale out of the box, should I then use the Asus facility to flash the BIOS with the newer version still? So that it's ready for upgrading to a Conroe at a later date. Would this create any compatability issues with using the Allendale on it until I decide to upgrade the cpu?
Thanks again.
