Parp!!! - Climat Prediction
18 Oct 2004
Cumbria
And so it begins:
21) Simon255 515,261
22) Berserker 491,531
23) Nick 490,195
24) spacehogster 487,647
25) Phekdra 421,563
26) grimgoth 404,696
27) ace_dent 399,711
28) the_running_man 365,418
29) Loudbob 330,379
They may roll over, but I ain't doing no rolling. I won't be at #22 by the time you get there. ;)
Assuming I can upload the four models I've got stuck before they time out. :eek:
I expect to be +10k shortly......
Plus, depending on prices Sunday - I may upgrade my Q6600 Rig to a i7 2600K.
We shall see....................
Check your uploads folks. Uploader.oerc has been down a while now and Milo is struggling to get it back up and running.
One of mine was past 10 days overdue so I reset the clock on it. Instructions in the CPDN forum if you need 'em.
Yes I thought the stats were looking laggy. Deadlines here not until September though so should be ok ;)
Uploads time out after 14 days irrespective of deadline, and since most CPDN workunits do intermediate uploads, you can have files waiting even though you have no completed results. They'll show up in the transfers tab if you have a problem.
HADAM3P is affected by this, FAMOUS is not.
Mine seem to be clearing pretty quick.....
On the up side I've now got my i7 930 stable (with H70) @ 4.2GHz and DDR @ 2000MHz.
Also, the i5 650 stable @ 4.3GHz (on Air) & DDR @ 1870MHz.
Finaly the Q6600 seems to be holding 3.24GHz and DDR @ 900MHz.
Lets see what can be done now.........just hope everyone else don't go getting the 2600k before I get chance.
Nice army there. Only got a Q6600 and i5 against that lot (not OC'd). I've got access to a couple Xeon boxes but it's not worth the job.
uploader.oerc was fixed yesterday (thanks Milo), so I've offloaded.
Well Sir......
I accept your challenge - even though Mid Rig has just thrown a spanner in the works - I still accept.
Hopefully, I can get it running in some shape or form.
:D
I wonder if I can back up both versions of windows using Win7 - and re-install on replacement hdd's?
Back later - gonna try something.
Not sure about Windows backup, but I've used a Linux Live CD more times than I care to remember for copying drive images.
Well, still won't boot with failsafe bios settings - looks like it's a hdd issue........
Me thinks I won't be able to create an image of winxp either if the hdd's are bust :(
Oh well - new hdd and a re-install it is then - but for the time being it's Win7 for seti & climate prediction.
Gonna try to repair XP before I order new drives - might get lucky.
If not - will image just in case I can manage to get it to a new drive.
On a side note - should have a replacement for the i5 650 in a few days so output should increase - if I can get the Q6600 up and running again.
Might return the rigs to F@H after I reach number 20 - just to see if I can challenge the top earners.
Further update:
New Case (Thermaltake V3) arriving Friday - Wee Rig to be transferred to it - i7 860 (lapped) to replace i5 650 with H50 (lapped to cool it) - 2 x GTX460's to replace 2 x GTS250's
WinXP Home Edition has arrived - New install will take place to replace WinXP Pro on Big Rig - GTX460 will take up squatting rites alongside 2 x GTX470s
Mid Rig - will take residence in Wee Rigs old case - 2 x GTX460's to be replaced by 2 x GTS250's
Second Gen i7 Rig will start build in 6 - 8 weeks (depending on oc'ing issues currently surfacing - and failing cpu's) - this will take up residence in Mid Rigs current case (Fractal Design R3)
Once the dust has settled watercooling project will resume on Big Rig.
Nice.........
I think I managed around the same.
First attempt at repair WinXP didn't work - looks to be a hdd problem more & more.
Have resized the partitions now - and moved XP into an area which should be OK - trying to repair again - but will order some hdd's in the mean time.
Edit: Repair didn't work - keeps locking up
No idea whats wrong now - as Win7 is on the same hhd's in Raid 0
Additional: Gonna try a clean install on some space I freed up in the same hdd's
Additional Additional: Clean Install Works - Guess I'm Gonna have to wipe Old XP and clean install (oh the joys)
:( :confused: :( :confused: :( :confused: :(
