Part Way Through Build - Urgent Help on Power
Hi, 100% installed as per the manufacturers instructions
"Is the fan tight on the heatsink "
It can be moved slightly with a bit of force but i think thats the design and how it fastens above the cpu so I believe.
"Have you set the motherboard to control the fan speed as the fan shouldn't need to run full speed all the time?"
There are four options in the BIOS and setting it too the lowest (Silent) it still does it
When the powers off if I manually spin the fan there is no noise however its like its the motor (which suggests its not catching against anything). Video here
View My Video
