Well i'm going to be brave and criticise it
First things i'm drawn to in the final pictures ;
Graphics card power cabling is not neat, looks wrong compared to the curve of the 24 pin, it almost looks like an after thought ( it'll fit though these holes, so we'll thread it through )
Non blanked PCI slots on the back of case ! A definate no-no, smacks of laziness.
Great photography though.
I completely agree with your criticism, but disagree with the reasoning. The cards and cabling look strange because of the spacing, being close to the socket and directly next to each other. Had they been typical 115X or 20XX layout or on an mATX board then it would seem completely normal but being oddly in the center doesn't help. More graphics cards is the obvious solution! I did originally think that it might have 3 so it seemed logical to do it that way.
Unblanked slots are a way of life, just like no windows, no front USB, no front audio, no reset button, no power button, no power LED, no HDD LED, no optical bay, no front mounted fan controller.... Choosing not to find or make blanks isn't lazy, it's just a constant reminder that you do infact need more graphics cards.
Needs more graphics cards, or less ATX.
JR
Perhaps my reasoning was slightly 'off '
If it was a showcase for the specific model case, then fine. But the lead post said it was a build for a friend so i imagined it was a custom build ( that would be built around the hardware ).
That aside, your reasoning for not including blanking plates ?
There is a world of difference between a couple of generic size ( albeit custom made ones by yourself ) PCI covers that would fit any of your cases, to adding windows and holes for power buttons, leds, opti drives etc..............
So my point still stands, why leave the PCI slots open, when you could easily block/vent the unused ones ?
