** PARVUM SYSTEMS L1.0 HAS LANDED **
rjk
rjk
Caporegime
8 Aug 2007
Emerging in the wake of a long list of showcase systems such as Project Magnus, Parvum Systems L1.0 is an elegant and unique presentation of what a watercooling case should provide the true enthusiast
Since early 2013, Overclockers UK has been privileged to be carrying the Parvum Systems line of cases. Parvum have redefined small form factor builds in the past two years by evolving and being open to new ideas and designs.
The ever popular S2.0 has developed over time from customer feedback and input. Over the past two years, every modding forum on the planet has gone crazy for these small acrylic boxes and for good reason. The success of the ITX 'X1.0' and the ITX Watercooling 'Veer' have spurred on more demand for a bigger Parvum case.
For 2016, Parvum have taken things to the next level and released the L1.0, a full E-ATX class chassis capable of holding huge amounts of cooling hardware and designed with ingenious layouts to allow end users to customise their watercooling hardware in ways not possible with other 'off the shelf' mass produced cases.
The guys at Parvum build cases how a hardware enthusiast would build a case, smart decisions are made and implemented rather than cutting corners to save costs and designs are improved and refined to offer every customer the best product on the market with a unique and personal touch. Each Parvum case is manufactured right here in the United Kingdom and are built in small batches to ensure exclusivity.
The L1.0 is built out of Parvum Systems signature 5mm high quality acrylic, the L1.0 has impressive scale but retains an enormous amount of structural rigidity. Layering techniques are utilised to give the sweeping lines and geometrical aesthetics of the case real functional purpose that stabilises the case and gives a sturdy foundation for heavy duty use.
Each case is individually cut using precise machining equipment. Each L1.0 is shipped flat packed with full assembly instructions.
Due to Parvum constantly upgrading and updating their designs, some small aesthetic changes may occur.
Most importantly, Parvum Systems takes great pride in the sourcing of their raw materials choosing a high quality, European sourced recycled acrylic. This ensures minimal waste in the production process as well as being kinder to the environment.
Specification:
- Material: Acrylic
- Dimensions: (WxHxD): 320 x 600 x 570mm
- Motherboard Support: ITX, ATX, E-ATX
- Maximum CPU Cooler Height: 200mm
- Maximum PSU Length: 280mm
- PCI Slots: (8x)
- External IO: (1x) Power Switch (1x) Power LED (2x) USB 3.0
- Drive Mounts: (4x) 2.5" (6x) 3.5" or (8x) 2.5"
- Fan Mounts: (4x) 120mm Front (3x) 120mm Top (2x) 120mm Rear (6x) 120mm Sides
Watercooling Support:
- Radiator Mounts (clearance for fans + radiator):
Front: 480mm (92.5mm)​
Top: 360mm (85mm)​
Sides: 360mm (135mm or 95mm when pumps are installed in Lower Chamber)​
- Pump Mounts: (3x) 50mm square or (6x) 20-70mm slotted holes
Parvum Systems L1.0 ATX Watercooling Case White & Black @ £299.99 inc VAT
Only £299.99 inc VAT.
ORDER NOW
Parvum Systems L1.0 ATX Watercooling Case Black & Blue @ £299.99 inc VAT
ORDER NOW
Parvum Systems L1.0 ATX Watercooling Case Black & Red @ £299.99 inc VAT
ORDER NOW
Would love to see a build in the white case, wont be long before someone is knocking one together.
Ohhh that's sexy as.... Curiously enough I just looked on the Guru3d webbie and their BOTM is using an unreleased Parvum case, that is quite nice, but nowhere near this 1...and it can fit 2 or more 360 rads. Oh my.
Dear Santa...
so there may be a little confusion, allow me to clear it up
since magnus was released. the end goal was pretty much always going to be this case.
there are a few variations and I think in coming months we may see a smaller ATX case that is a little more affordable and not 100% focussed on mental watercooling setups but this is where these prototypes are coming from. you will be seeing a lot of Parvum show systems and project logs in various smaller form factor ATX cases whilst this is refined.
the L1.0 remains unchanged though and is very much their flagship case.
This is truly a nice case, lots of room for your water cooling goodies, there's going to be some nice builds on OCUK for 2016. :)
this is their flagship product. plus, you have to remember that there is a crazy amount of wc hardware that you can put in this. find a comparible case and it will be similar money
and in my opinion, not look half as good.
They are a little bit more expensive than i thought they would be, BUT and it is a big but (hehe, big but) I know they have worked a hell of a lot on these cases and I have seen what can be created. They are excellent, a lot of thought, R&D and time has gone into these and they are worth it.
Glad to see they have finally released it!
Yeah, well lets face it, if they sent them prebuilt by the time they arrived at your house they would be flatpacked, so they might aswell leave them that way.
I'm not sure why you would think that. They are just over double the price of an S2.0. with that you are getting over double the amount of watercooling room, over double the size, double the time to manufacture, double the materials used to build it, double the packaging materials cost etc etc.
Will these be same as the previous cases? as in build up yourself?
correct :)
Having built our sample, I reckon they would do ok in transit in honesty. The one thing that would be the issue is finding packaging suitable for something of this size!!!
here is our L1.0 next to me for scale [I am 6ft tall]
Ooooohhhhhhhh.
I have a 550D and a CM Cosmos 2 but I've wanted a L1.0 for a while. Would finally fit everything in...any Christmas deals happening?
