*jizz*
Nothing more to say ;D
Thanks.
I love you th----------------------------------------------------------------------------------------is much.
Like the good free marketeer that I am, I will demonstrate my love by showering you with money should this case make it to market.
Yes yes yes yes yes yes yes yes yes yes yes yes yes !![]()
Seriously amazing build![]()
Cool stuff![]()
You mentioned some problems with weight.
What kind of acrylic do you guys use?
I think about using polycarbonate in my next project.
It looks like much better choice than normal acrylic.
Do you have any experience with it?
I looked it up on wiki and range of aplications is impressive, computer cases are also mentioned, but I also checked prices and its about 15-20% more expensive than perspex.
So I'd appreciate your opinion![]()
Cheers
Cannot describe how happy it makes me to see all your components slotting and routing through the holes. I am too much of a neatness fan
The way the rads & fans are setup is divine.
I've just spent the best part of a day re-cabling a server and patch panels and to sit down and see such a clean build puts a smile on my face.![]()
Its coming along nicely good work![]()
That tiny tubing between rads. Love it![]()
It's like a wee baby tube![]()
So tidy.
Loving it.
Looking great
Want to do mine for me?![]()
Agreed,Anyway, digressing too much for this thread!
That is f'n sweet. Love the cable routing holes in that panel.
By the way, I always wanted to ask you, where do you guys get those little 'cube connectors' from?
Do you make them or buy them and if buy, where?
Cheers
We're in the process of a rollout of fibre infrastructure (ok, it had stalled for 10 months, progressing more now) so when I started (2 years ago) I made the purchase of a big 19" cabinet to replace a 6U wall mounted one... Thankfully my users wouldn't know where to start and dare not touch anything!
How many loops is this system heading towards? The acrylic 'blocks' used for spacing looked very similar dimensions to pumps... 4 pumps?!![]()
Agreed,
4 pumps would be outrageous
but I am hoping for at least a couple, and multiple coolant colours![]()
