Two loops! Two coolant colours. The theory is 360mm, 240mm & 240mm for GPUs. Then 240mm, 240mm & 240mm for the CPU, Mobo & RAM.
Should be suitably overkill.
That's more than overkill, that's insane!
Is the white XSPC AX360 rads going to be available or were they special treatment? (I quickly trawled through the thread for the answer but I didn't see it)
Scratch that, I was just looking a supplier who didn't have them. I have found them elsewhere
Those thin rads going to cope with those 3 cards? Looks awesome as usual. You should do build videos showing how you set up all the tubing.
you can see the dense FPI of the cores.
With such fin density, are there any fans you'd recommend/recommend staying away from?
I'd just grab anything that can move a lot of air really. I wouldn't say the fans I choose are 'perfect' but I had so many rads it wasn't as much of an issue to run fans pushing less air etc.
The more FPI the more that''ll help dissipate the heat but the denser that rad will become. You'll just need to be sure you've got something that can smash a nice amount of air though the dense fins![]()
