- 30 Dec 2013
- Liverpool
Personally I don't think there is going to be a 1080 Ti, their simply can't be, right? lets look at the facts shall we?
GTX 680 2gb Vram 1536 cuda cores 256 - bit memory 32 rops
GTX Titan 6gb Vram 2688 cuda cores 384 bit memory 48 rops
GTX 780 3gb Vram 2304 cuda cores 384 bit memory 48 rops
GTX 780 Ti 3gb Vram 2880 cuda cores 384 bit memory 48 rops
GTX Titan black 6gb Vram 2880 cuda cores 384 bit memory 48 rops
GTX 980 4gb Vram 2048 cuda cores 256 bit memory 64 rops (GTX 680 successor)
GTX Titan X 12gb Vram 3072 cuda cores 384 bit memory 96 rops (GTX Titan successor)
GTX 980 Ti 6gb Vram 2816 cuda cores 384 bit memory 96 rops (slightly cut down)
GTX 1080 8Gb Vram 2560 cuda cores 256 bit memory 64 rops
Nvidia 'Titan x' 12Gb Vram 3584 cuda cores 384 bit memory 96 ROPS
The last time we had a cut down Titan was in the kepler series followed by the 780 Ti and the titan black with fully fledged GK110s now the problem is where can a 1080 Ti sit in? if you look at the history of the cards above each successor has at least SOMETHING doubled whether it be Rops or Vram.
This new titan card succeeds on doubling the Vram when compared to 980 Ti which a 1080 Ti would be the successor too yet matches the Titan X maxwell.
Where can a 1080 Ti fit into place? even if it matches the specs of Titan X with less cores what about the Vram 9gb? as that's the least they can put on a 384 bit interface whilst having more memory than the 1080/1070.
Personally I feel like when AMD brings something to the table a full fledged Titan will launch with 16gb Vram and this titan will get a heavy price cut and all of a sudden it'll feel like a bargain compared to what it WAS selling at and the fully fledged titan when that'll only offer around 10% more performance. Again all speculation but I just don't see where a 1080 Ti can fit in to this
am giving advice. My advice is nvidia can stick the over priced GPU where the sun dont shine.
