The falling glass will make some noise, but they will be in and out before Agnes next door has peered through the blinds to see what the noise was
This video shows how much tougher it is to get through laminated glass. The second one is toughened glass, which is what most patio doors in the UK use. Obviously this example is a lot louder as hes using a baseball bat, but there are quieter methods of breaking it. The main thing is that it breaks the glass into tiny safe pieces so they can quickly break the glass and be in and out with whatever valuables are lying around.
All I was trying to say is that I wouldn't go spending loads on fancy bars and things that hold the handles together etc as they wont help much. And that if you really dont want someone to break in the get laminated glass next time you have a door installed
. This video shows how much tougher it is to get through laminated glass. The second one is toughened glass, which is what most patio doors in the UK use. Obviously this example is a lot louder as hes using a baseball bat, but there are quieter methods of breaking it. The main thing is that it breaks the glass into tiny safe pieces so they can quickly break the glass and be in and out with whatever valuables are lying around.
