PC Build for BF1 - £500 possible?
i mean my thought behind it was using what Daaave had suggested, then adding case + monitor to that and possibly a slightly better GFX card if the budget let me
as i said I dont know anything about hardware and whats good / compatible, i just know how to put it together.
obviously if its not possible then that's fine and i'd have to sacrifice the monitor until a later date
appreciate everyones help so far and apologies if i dont seem grateful because i am
If you bought these,
https://www.overclockers.co.uk/xfx-...s-graphics-card-with-backplate-gx-23b-xf.html
https://www.overclockers.co.uk/aoc-...descreen-led-monitor-black-red-mo-030-ao.html
Dropped the overclocking, case and reused the memory.
Intel Core i5-4690 3.5GHz Quad-Core Processor
Biostar Hi-Fi H81S2 ATX LGA1150 Motherboard
Kingston SSDNow UV400 240GB 2.5" Solid State Drive
That's about the biggest upgrade you can make for sub £800.
If you want to move to 2560x1440 or higher then a faster graphics card would be the way to go.
£200 on a non-K Haswell :eek:
Its still going to perform fine for your use but if buying new these days it seems a shame not to go Skylake. It would mean getting DDR4 RAM though as there are no Skylake DDR3 motherboards in stock now.
It is good, but just keep in mind you drop 4x300Mhz worth of performance with the Skylake.
This is true, and despite small IPC improvements from Haswell to Skylake, the 6500 is a little slower. I would aim for the 6600K for a few extra quid as overclocking is really easy anyway :)
Morning folks,
Pay day has been, I've booked off Thursday / Friday to do the build and am going to order it today :D Can someone just give this a once over and confirm it is all compatible? I upgraded the RAM to 16GB and reduced the SSD to 120gb as the 240 one mentioned is out of stock! Also just a quick question how easy are SSD's to install? Never used one before.
My basket at Overclockers UK:
Total: £879.23
(includes shipping: £12.30)
and I will be accompanying this with the reuse of the below from my current pc :
1 x Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX)
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply
1 x BitFenix Merc Alpha Gaming Case - Black
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM
1 x BitFenix Spectre 120mm Fan - White
Hi Jigger,
Thanks, hadn't noticed that was 4 x 4 , I've now changed too 2 x 8 and placed the order, being delivered tomorrow :) I have the afternoon off work to complete the build and can't wait! Will post back once done.
Thank you to everyone for all the help, it was really appreciated.
