10 Jul 2015 at 20:16 #21 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare They are roughly the same. the 970 is newer so has newer tech.
10 Jul 2015 at 20:21 #22 Drake5 Drake5 Soldato OP Joined 12 Dec 2005 Posts 14,624 if you had to chose a 970 based on brand which one would you go for
10 Jul 2015 at 20:59 #24 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Drake5 said: if you had to chose a 970 based on brand which one would you go for Click to expand... Gigabyte G1 gaming.
10 Jul 2015 at 21:10 #25 Drake5 Drake5 Soldato OP Joined 12 Dec 2005 Posts 14,624 I could just risk the Zotac I guess..... If you do get coil whine is it something that is very loud? Does it affect the performance of the card any
